how to save fuel on evo?
Old Aug 30, 2012, 04:27 PM
luislm21's Avatar
i have an evo 7, im from dominican republic,..i want to know how to improve mpg on my evo. i use it daily and fuel consumption is 15mpg so i think that the car can reduce that consumption...
i will put the oem airbox for daily use, ill change the spark plugs(i want to know which to use), and the engine oil and filter(i want to know which brand to use)
Old Aug 30, 2012, 04:33 PM
EVOeroc's Avatar
Not to be mean about it or anything but if you're concerned about the fuel consumption then maybe you shouldlook into a different car. Agreed,mpg is crappy on these cars but its a high maintenance sports car. Opinions to improve? If you have a boost controller turn it all the way down,always check tire pressure, and use a fuel injector cleaner so that the injectors are releasing enough fuel. G/l with the mpg
Old Aug 30, 2012, 04:38 PM
okevolutionVIII's Avatar
A tune to lean out the cruise range to 15.2AFR will help as well as staying out of boost and driving the car smoothly.
Old Aug 30, 2012, 04:52 PM
MRolla's Avatar
Stay out of boost and get a tune vehicle tune rich so you don't blow it up. No need the stock air box any intake will do just shift at low rpm or do 1-3-5 so you don't hit boost g/l
Old Aug 30, 2012, 05:38 PM
DeeezNuuuts83's Avatar
Wanting to improve mpg isn't unreasonable, especially when the OP is only getting 15 mpg. I can afford the gas without any problems, but I still try to get better gas mileage when I can.
Always check your tire pressures, but if you're only getting 15 mpg (though a lot will depend on how modded your car is), it's likely that your driving style is sucking down a lot of gas. I have every single tank of gas from my two Evos documented on MS Excel, and my worst mpg from normal driving was 17.8 mpg. You probably just give the car a lot of gas very frequently (which is obviously fun), but accelerate more slowly and shift at a reasonable rpm while going into a higher gear when it's appropriate to do so... I've seen so many stick drivers stay in a lower gear far too long when they're just driving in a straight line at a consistent speed but without the need to accelerate.
Old Aug 30, 2012, 05:47 PM
AznEvoIX's Avatar
Tire pressure, air/fuel ratios, good tune if you have aftermarket parts. It all adds up.
However the best way to save MPG on the Evo?
Get a daily driver.
Old Aug 30, 2012, 06:54 PM
kanovic's Avatar
sell it
Old Aug 30, 2012, 07:06 PM
AznEvoIX's Avatar
^ lol
Old Aug 30, 2012, 08:20 PM
reboundicon's Avatar
For most Evo owners fuel, isn't really a concern as this is an issue we knew of before purchasing the car. You can't expect the gas mileage of a civic with awd and turbo in the mix lol.
My advice if you want to "try" to save on fuel would be to stay off boost, check your tire pressure regularly, make sure you have a good tune and try not to drive around any overweight women lol.
Old Aug 30, 2012, 08:27 PM
luislm21's Avatar
so its not a problem the low MPG but some users cars MPG is 17mpg , so if i can get more MPG it better for my wallet.. my new AFR is 14.5, so ill try to drive smoothly,.. i need to know about spark plugs for my evo, and the engine oil and filter....
i want to get at least 17MPG
i have a different evo, this is Evolution GT-A..
Josh x's Avatar
1-3-5 shifts
Old Aug 30, 2012, 09:43 PM
xRoguex's Avatar
23.5mpg in mine. =) Is that good? Hahaha
Old Aug 31, 2012, 08:38 AM
89Saleen141's Avatar
Yeah i shift at around 3k when i'm just cruising to somewhere. I get around 17 - 21 mpg depending on how much i get into the boost.
Old Aug 31, 2012, 11:07 AM
402nebraskakid's Avatar
I get 17-22 city 21-26 hwy and that's 3k shifts
Old Aug 31, 2012, 11:10 AM
ReaperX's Avatar
Remove the lead from your right foot.
Quick Reply: how to save fuel on evo?
