Suggestions on next step?
My evo 8 currently has these mods:
Buscher turbo back exhaust
Aem intake
MBC set at 21 psi
280/272 cams
AMS front mount
My injector duty cycle is pretty high at about 95%
I was wondering whether I should get injectors (if so brand recommendations) or hard inter cooler piping.
My tuner said I could safely add about 5 psi with upgraded injectors first. Hard pipes would obviously help however I am on a budget or I'd do them both at the same time.
What would you recommend?
Aem intake
MBC set at 21 psi
280/272 cams
AMS front mount
Not that it will explode right away, but routinely hitting anything much over 25 psi on stock turbo is gna to limit its life.
As stated already, a walbro 255 will bring down the ink duty cycle. The real question is what is your goal for the car, as there's no reason to build it up twice!
I ran out of stock injector with a 255 fp once I added hks 272s on my stock 8 turbo setup. Upgraded to rc750 (this was a long time ago before running 1000+cc injectors was feasible for the average street car). I'm on hta green now, still with same 255 pump and 750cc and I'm hitting 90% idc with just over 400whp running 28psi on 93. I would get fuel pump and injectors. There's lots of options for pumps and injectors. Ask your tuner what he recommends. I've had great luck with RC injectors. Lots of people run FIC too. For a stock turbo car, pump gas, a 255 should do fine. I would go with around a 1000cc injector which will give you plenty of room to spare. Again, whoever tunes ur car will have a preference of fuel components.
Piping is helpful. LICP does the most. Will help with spool. UICP is nice if ur got spare $. Short route arguably adds a few hp and may help response since its like 12" shorter than stock. It does make ur bay look nice and gets rid of the stock black couplings which are known to expand with higher than stock boost. I've always liked fit and finish of ETS piping.
25-26psi is pretty standard for 93 octane tuning as long as your have a good fmic and proper fuel supply.
My next step after this is going to be either 9 turbo or fp black. So I should probly do 1000cc injectors my tuner recommended fic. So I'll be looking for those. But before upgrading turbo I should definitely do fuel pump correct?
turboback1243
Jul 6, 2014 04:56 AM
jhinkle
May 31, 2014 09:35 AM
Reactus Maximus
Oct 22, 2013 04:44 AM
