Tial BOV Q Vacuum at idle
Well im installing S3 cams this weekend. From what i have seen/read people idle at 1,100-1,200 RPM. The Vacuum reads -10 / -12 Now the Black Tial Spring is recommend for -8 / - 11 the White Spring is -12 / -15 What spring do i get?
I run the S2 cams. Idle is a lopey 1000 and vac is about 11.8. I errred on the stiff side and went with white. Its fine and working the way it should. You don't want to end up to soft and it floats at idle. I'd say you need to install your cams first and see what your new vac number is before you swap your spring.
lghtngyello03
Feb 6, 2017 11:00 AM
CJ2X
17
Nov 13, 2012 11:05 AM
bnr34rb26dett
Feb 27, 2011 10:45 AM
