evo ix clutch pill delete
Old Sep 12, 2012, 08:52 PM
maxboy01ae's Avatar
can anybody explain to me what this thing is or where is it located im new to the evo world so im still learning dont judge me. thanks
Old Sep 12, 2012, 09:01 PM
Ev0ikon's Avatar
It's a metal pill with a tiny hole (to let fluid flow through at a slower rate) inside the slave cyl.
Old Sep 13, 2012, 07:37 AM
silverofs's Avatar
pull the line off of the slave cyl and you will see it in there, just pull it out put the line back on and bleed the clutch.
Old Sep 13, 2012, 08:42 AM
hppwdn's Avatar
Is there any benefit to removing this at low power levels? Less than 400whp?
Old Sep 13, 2012, 09:40 AM
djdnav's Avatar
Find the thread about replacing the clutch line. The restrictor reduces the flow of fluid which makes clutch engagement sloppy and incomplete regardless of power level. Taking the pill out allows more deliberate engagement.
Old Sep 13, 2012, 09:46 AM
EvoIIIAj's Avatar
What I want to know, is removing it just giving you more of a chance to pop the clutch clip? I read that somewhere and that's why I haven't removed mine yet.
Old Sep 14, 2012, 08:00 AM
gray9evo's Avatar
So does someone know the reasoning behind why Mitsu would implement this clutch pill?
Old Sep 14, 2012, 08:13 AM
maxboy01ae's Avatar
With all this comments I might not even remove the pill. Im close to 400awhp exedy twin anf lately my clutch pedal feels a little different when I first put the twin in. Was wondering is the pill is gonna help. Engagement still the same.. launch it twice since I put it on. All my drivetrain is from shep.
Old Sep 14, 2012, 08:30 AM
FJF
FJF's Avatar
So that idiots who drop the clutch at 7K wouldn't file warranty claims.
FWIW, my clutch pill has been out for ~5 years.
Old Sep 14, 2012, 09:20 AM
Ev0ikon's Avatar
^What he said.
It's to reduce the clutch clamping speed for "inexperience" drivers.
I got it out only a few months after getting the car in 2003. I could not shift quickly with it in.
Old Sep 14, 2012, 09:51 AM
maxboy01ae's Avatar
I removed it on my e39 when I had it I notice the difference right away. So **** it which one should I get I wanna get thst one piece from master to slave any brand in particular that works the best on evos.
Old Sep 14, 2012, 10:03 AM
llDemonll's Avatar
so...removing this will make engagement/disengagement "faster"?
Old Sep 14, 2012, 10:18 AM
Ev0ikon's Avatar
You got it.
Old Sep 14, 2012, 10:21 AM
Ev0ikon's Avatar
If you are asking about the hydraulic line for the clutch you should just replaced the "rubber" section.
Old Sep 14, 2012, 05:20 PM
lostsoulsevo's Avatar
i did the pill delete and stm master to slave clutch line, clutch feel is a lot better and i noticed the clutch pedal is not as stiff. i was kinda tripping out cause the clutch pedal is springy now and WOT shifting is super smooth.
Quick Reply: evo ix clutch pill delete
