TRE diff and Whiteline sway bar
![](http://i274.photobucket.com/albums/jj241/masonh66/004-1.jpg)
![](http://i274.photobucket.com/albums/jj241/masonh66/003.jpg)
![](http://i274.photobucket.com/albums/jj241/masonh66/002.jpg)
![](http://i274.photobucket.com/albums/jj241/masonh66/001.jpg)
recently sent my diff off to TRE for the 12 plate max-lock service.he hooked me up with a deal on the glass and and HD ninja side cover so i went all in and got everything.
i also bought the Whiteline rear sway bar,end links and the new mounting hardware they sell.i think the mounting brackets for the sway bar are a new item so i figured i would take some pics and post them.everything i got from Whiteline is very nice and high quality.the brackets for the sway bar are much stouter and nicer than the OEM brackets.
the sway bar is the same size as stock,but is adjustable so you can make it 22% stronger i believe,but with these brackets it will be way more than 22% if you use the stiffest adjustment hole.
the factory brackets and end links look like toys compared to these.i should have gotten better pics of the end links and i can if anyone needs to see them.
the sight glass on the diff cover is a nice touch and makes filling it up so much easier.i think you can see the pink shockproof in one of the pics just above the full line.
thanks for looking.
can't say yet.i just installed it and i'm still waiting on my motor.i'm doing a ton of stuff to the car while it's down.the TRE diff,carbon fiber drive shaft,end links front/rear,sway bar with brackets for rear,billet torque solution motor/trans mounts/tie rod ends/going to a 2.4L with ETS 6466 turbo kit.i also dumped a bunch weight,the car should be under 3000lbs for sure.
i will post my review of the above parts when i get it going again.
it was a week or less even with 2 day shipping both ways.
i was actually going to leave the front sway bay stock,but add stiffer end links.
i am not going to be racing it in the track though,only drag racing.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
incog6
18
Jun 14, 2010 08:41 PM
incog6
Mar 1, 2010 01:51 PM
lethalvenom
19
Jun 2, 2009 07:07 PM
