what gauges
what gauges
hey guys im looking at buying 3 gauges, i already have 2 in mind, aem tru boost, and the aem wideband, i just need a 3rd gauge i want to try to keep it aem and digital but which one oil pressure or oil temp?
ok so oil pressure it is, i assume the AEM oil press gauge comes with a electronic sending unit, is there a oil passage plug that i remove and stick the sending unit in? if so anyone have any idea where that little booger is at?
FWIW you only need a warning light for when oil pressure suddenly drops, you don't need a fancy gauge for that.
http://www.jegs.com/i/JEGS-Performan...ductId=1321858
I would suggest oil temp or EGT since both of those are much more gradual.
![Dunno](https://www.evolutionm.net/forums/images/smilies/dunno.gif)
I've always been a fan of a coolant temp gauge as well. Much more accurate than stock gauges in the cluster. In my last car I ran wideband, boost, oil pressure & coolant temp.
I like having the EGT gauge. Boost, EGT and wideband is what I run. Oil pressure is good to have BUT... gauges that have memory recall and warning lights is the hot ticket because the thing is... when your at 7 grand breakin the law..and the adrenaline is pumpin'.. you ain't got time to LOOK at your gauges.. LOL when something goes wrong... I want lights to start flashing and warning buzzers to start sounding..lol
Is there a company out there that makes a dual function setup? For example, I know a company for Audi that makes a dual digital display on the same 52mm gauge. So you could have oil pressure and EFT on the same gauge
riceball777
21
Oct 22, 2013 09:41 PM
emotart
Dec 8, 2012 04:17 PM
