stiff gas pedal after fixing throttle body seals?
hey guys after spending some time on replacing my throttle body shaft seals i finally went for a test drive. i placed my foot on the gas and it was a little stiff at first but once i applied some pressure it went down. This only happens when the car is on so im guessing its do to the vacuum on the throttle plate. any ideas how to fix this please help
thank u
-chris
thank u
-chris
not really, here is an example, car is off- gas pedal moves freely and so does the throttle body, cars on- gas pedal feels like something is holding it back for about half an inch until i push more and it feels normal. so the problem only occurs when the car is on and when i first apply pressure to the gas pedal. and the car revs to 3000 rpms when i first start it also
Do u have a picture of what the spring should look like when it's on properly? Besides the pictures from the write up. Also would it matter that it only happens when the cars running?
Do u mean even remoig the new deals again?, and I'm not sure if I have them both facing the correct way. Does the copper part of the seals face inward towards the tb or outward
thanks everyone for the help i removed the tb and i had to reverse one seal and the clip ring was not in the correct position so the circular plate have play from right to left. it works nice now i just need to adjust the idle from the tbs
Warrtalon
18
Jan 20, 2011 03:36 PM
