Supertech Valve spring install question.
So on top of the spring is a retainer, then you have the spring, then you have the seat and then you have a small thin black"washer" Underneath the seat. I'm telling you that is what was on my car. And would like to know if i still need to have it under the "seat"... I'm replacing my stock valve-train with super tech titanium dual springs with Ti Retainers and seats. Also replacing my valve seals.
Actually it's a shim for stem height,not pressure as that is determined by the spring.
Are you doing this out of the car,head off?.
If not, check the spring height set up of each spring and valve with a electric sliding guage. If they are all within the same spec you should probably leave that one with the shim in place, put the new spring seat on and assemble like normal.
Checking stem height and guide wear is what I would do if the head was off.
Good luck.
Good luck.
Good luck.
Good luck.
Thank you sir. head is off the block, I'll check the spring height tonight. I'm guessing they should all be around the same specs?
1 Post
You increase spring pressure with a shim
You grind valve stems to adjust height...
A shim compresses the spring, but does not move the valve at all..
Jsiebert
Nov 15, 2014 06:49 AM
BlackEvo_5
May 28, 2013 07:01 AM
Brsox10288
Nov 10, 2010 01:36 PM
