Bolt on advice
Bolt on advice
Hey everyone,
Well i'm quite keen to do a number of bolt on mods to my recently purchased evo vii, but being from New Zealand a lot of the parts that EvoM promote aren't readily available from stores here...
So my question is, would some of you mind recommending some good brands of the bolt ons listed below in which I can order online and get shipped internationally?
The mods i'm currently looking at doing are:
TBE
O2 Housing
LICP
Exhaust Manifold
Fuel Injectors (roughly 800cc)
Fuel Pump (Will be getting the Walbro 255HP, just need to find a good source)
So far i've found a few stores online that will sell these, but i'm wondering if there are any other people in a similar situations who have had good experience with ordering some of the above products online.
Cheers
Side note....any other kiwis out there?
TBE
O2 Housing
LICP
Exhaust Manifold
Cheers
When I say TBE, I mean the full package, so yea I would want a Test pipe etc
I've already got a aftermarket intake and i'm wanting to change the exhaust manifold because a previous owner put an external wastegate on it and i'd prefer to tidy it up whilst getting some gains.
You're wrong. You see the most gains from a LICP the uicp is mostly for looks and if you want a run a different BOV. Honestly get 1000cc injectors that way if you decided to run E85 you can!
This thread has gotten way out in left field with bad advice...OP i think the mods you listed are a good start that pretty much covers the evos weak spots...if it has any, After those mods i would look into some cams (I love my kelford 272s) And a tune
Hey everyone,
TBE
O2 Housing Not going to do much for you and decrease reliability
LICP same as above
Exhaust Manifold pointless on a stock-ish car
Fuel Injectors (roughly 800cc) You don't really need this
Cheers
TBE
LICP same as above
Cheers
since you already have an intake, a TBE would be the next mod to get to see most gains. LICP > UICP . you wont need bigger injectors if you are running the stock turbo. after market mani isnt needed unless running a more serious setup. fuel pump is a must. also cams could be a nice upgrade as well (love my 272s too !), maybe just the shafts, springs would be good but wont b really needed on a stock turbo either.. and def a boost controller AND a tune it to maximize reliability and power output of the mods.
depending on your budget ebay has some decent stores that sell exhausts, otherwise possibly look at importing etc from jpn/aus/us
So back to my question has anyone got some recommendations for the mods i've listed that I can get online? Bearing in mind my evo is an Evo VII not VIII
My priority mods are the TBE, LICP and fuel pump
