Evo 8 Mpg
Evo 8 Mpg
Debating on going e-85 or staying pump
I'm getting 200 miles to the tank on average is that common? Not sure if a tune will help raise it a bit.
Goal is to make it 500hp daily but I will be getting a fp black later on the road. But if e-85 is a tad lower on the mpg I will be fine with that
E85 isnt a tad lower its alot lower lol. But however if you are getting 200 out of a tank right now you deff need a tune or check some sensors. unless you are boosting non stop. e85 can get you 150 pushing it 200miles a tank. you should be getting 250-275 now with 93
I get 200 per tank on both 91/e85 and I daily drive my car half freeway half steep hills. I thought my e85 mpg would be much lower but if you don't smash in the gas just because you wanna feel the e85 pull you get about the same and you pay like 15$ less, at least in SoCal
So I guess if I have nothing to lose just run e-85 I'm used to the 200 per tank I thought I could get a little more out of it. I guess I could give it a shot is it hard finding e-85? I will be buying a drum and fill it up, but if I wanted to road trip around should I just get a second map?
Sorry for the questions just interested in this new fuel route
