Oil pressure remote kit help
does anyone use the Extreme PSi remote oil sender kit, if so, how did you install it?
I feel like i just wasted 40 dollars as I anyway I use it , either it doesnt fit or it's extremely close to a moving part
I have a oil pressure and temp sensor to connect, I already removed the plugs on the housing and I have the 2 42 draft design adapters.
THank you for the help
Remove Allen head plug on oil filter housing.do not under any circumstance try removing without heating it up.get a map gas torch at Home Depot.The torch is cheap and you'll find more uses for it like ex bolts,rusty suspension bolts etc
05-EVO-GSR
Aug 25, 2015 08:45 PM
Inprogress
May 15, 2014 06:42 AM
