Taking wing off help !
ok guys i know theres like 100 threads on wingless and taking it off but i couldnt find any mention of anyone saying how they removed the plastic clip. i undid the two bolts each side (2 bolts 2 screws) and hairdryer the tape but i c the plastic clip still .. do i pry it off or will it break the clip? how do remove the plastic clip as theres no hole under neath the trunk ????
TIA
TIA
TIA
TIA
also ive taken the wing off now but in the holes where the clips went in theres still a bulge where the plastic clip went in which seemed quite hard to take off my boot ?? ill try again tomorow and post pics
oh.. my trunk is okay.. i've taken the wing off.. didnt have any rust, just left over residue and where the plastic clips went in is still a bulge which im having trouble taking off but will look further tomorrow as it got dark before so i left it til tomorrow
When pulling the plastic clip out you have to be careful not to bend the trunk. That's the sheet metal or body panel we are referring to. Taking the wing off shouldn't cause any bending of the panel. I used a screw driver and pliers for the first side which bent the metal a little. I'm not worried because I'm going to weld the holes shut and repaint. However, the other side I used a body trim clip tool.
with the residue can i use metho to clean it up ?? or warm water and scrub?? i dont think we have goo gone in aus ! ..
also is this what you guys are referring to to be careful when taking off? ?
cos this is what im having trouble taking off
have had the same electrical tape on for the last year...still going strong
until I go to an autobody shop and get the holes covered up.
i removed this using flat screwdriver.like i said its not important,cause the bolts holding your wing.and then i covered the holes with plastic plugs from autostore.some ppl using electric tape,some round vinyl stickers from hobby store.and others simply pay $250 for body shop to cover it and respray it.
Blitz
Mar 2, 2010 10:27 PM
