Question about spark plug wires
I'm getting a CEL (cylinder 4 misfire) and I'm buying new spark plugs and wires. I was looking at Magnecor 8.5mm Spark Plug Wire Set http://www.maperformance.com/magneco...e-set-evo.html
My question is has anybody used em and are they worth the $86? Also what plugs should I go with? My guess is one step colder than factory plugs. I've got a Cobb AP Stage 2 map, AMS turbo-back exhaust, AEM intake, Walbro 255lph fuel pump, Grimmspeed bcs etc etc
Well what kinda miles do you have? I had magencor 8.5mm for a while, then switched to a coil on plug system. 86 compared to 500 is a big difference, but my whole thing is that's one coil firing for 2 cylinders, compared to a coil on plug system because they do each cylinder. If your stock coil goes bad then ur car could really drive funny. Good luck.
Spoolinup is pretty good too, and cheaper. http://www.spoolinup.com/
Str8Pimp
Feb 15, 2013 06:48 AM
nytalonTSi
Oct 13, 2010 05:44 PM
