Bolt size for LICP
Bolt size for LICP
Removed my bumper so fix a massive boost leak and reprint my mesh and found what I would call an issue.
The LICP (passenger side incase I have my terminology backward) isn't bolted to anything. Anyone know what size bolts fit the threads there? I had a 6mm layin around and its too small so I'm thinking 8 or 10.
Ill throw some pictures up for everyone to laugh at later.
Took two trips but they are 8mm.
This what I found when I pulled the front clip. The fan control module was also hanging by the connectors yesterday. I couldn't figure out how it mounted at first because he BENT THE BRACKET BACK! There is a reason I refer to the previous owner as d!psh!t. Major boost leak is fixed, LICP is bolted down, fan module is bolted down too. I even got the boost leak tester to blow off with my sister standing right next to the car.
EvoSupersonic
Dec 12, 2012 11:37 AM
