Hole under headlight ?
Hi there, i just bought a new set of jdm evo 8 headlight, they came with no bulb and ballast, but there a hole under that i dont know what goes there
If the same cap is on my oem gsr 05 no hid headlight, then im fine, if not i am gotta use something to cap this hole off !!!
Thanks
Thanks
Its not where the ballast is mounted, its under the headlight!!
If there is a same cap on my non hid headlight then im fine, if not i am going to make a cap with Holesaw and some rightstuff
yes it is. See those 3 screw holes in the bottom? The OEM ballast screws into those. Then the wires come out the top of the ballast, directly into the headlight, and run to the back of the projector, that way all the wiring is contained internally.
Thanks
Thanks
Check this video:
FS[Northeast]: OEM Evo IX MR HID Headlights
Frew
14
Jul 16, 2014 03:15 PM
