ACD pump in trunk?
this may help Scroll down on the first page it will tell you how r/ternie did it. Sure he would be willing to help to if you needed to pm him
https://www.evolutionm.net/forums/al...4-efr7670.html
Thanks but thats not exactly what i'm asking. I've already done it but my motor is in the trunk not exposed under the floorpan.
No real path or how to that I followed other than meeting the criteria for what I was wanting. 1) to move it away from the front for better weight distribution, 2) move the pump away from the elements, 3) mount it in a place where it would be securely mounted, 4) for bleeding purposes I wanted it low but not sure if I necessarily wanted it lower than the bleeder fitting on the tc for ease of servicing in the future.
From what I gathered during my install I found that the metals used in the trunk floor is rather flimsy and I had to reinforce the oem bracket in order for the pump and bracket not to move around so much. I chose to mount mine on the right hand side of the spare tire well in the trunk because it was the lowest point back there. I then have a ss line with ptfe inner liner routed up to the tc with a crimped on an fitting. I think if I would have sourced a hard line it would have been easier to route in the long run, but this works.
Im not sure if it matters so much for bleeding the system as much as draining it actually though.
