Weird smell when hot air is on
Hey everyone,
Just wanted to see some opinions on why my hot air blower is giving off a weird smell, it kind of smells like a barn, musty I guess, but it only smells when the hot air is blowing. if the AC is on, there is nothing, and with AC off, cold air blowing, there is nothing. Could it be a mold/musty cabin air filter? or some kind of rodent running a muck in the blower somewhere? What do you guys think?
Thanks
Thanks
Is this on the Evo 4 from your sig? Im not sure if those have a cabin filter or not. What I would do is spray some a/c system disinfectant spray. A few different companies make them. Spray it through where your cabin filter would be, or where your blower is at so it sucks it through the system. Follow the instructions and spray the hell out of it, then replace with a new cabin filter if your vehicle is equipped with one.
It is indeed the car in my sig. Do you happen to know where the intake to the blower is?I know there is the one under the center console I believe, but there is also one under the hood, is there not?
Im not really that familiar with the evo 4. I assume it might be similar to a mid 90s galant that we had in the U.S. Usually the cabin filter is placed in an area behind the glovebox if the vehicle is equipped with one. You have to remove it in order to spray the disinfectant. If there is no cabin filter then you can spray anywhere really that is sucking the air in through the system. Ideally it should be after the blower, but really it doesnt matter. I have done it both ways and has worked fine.
It does not smell like antifreeze, the closest thing I can relate it to would be a barn or something, kind of like hay/animals. That is why my first thought was a rodent or something.
