HELP with shifter cable (underhood) bushings
Hi guys
I just installed my shifter base bushings without much drama and am now doing the shifter cable underhood ones
i got the stock small one off without too much difficulty but it seems as though the large (bottom ) one is extremely hard to take off and with minimal space i am having a lot of trouble getting it off? ?
any one have any ideas of what to do if the stock bushing is seized to take it off ? ?
cheers thanks in advance
I had same problem. I put back the oem ones. Took it to shop and the large one was seized on there and they took out the entire assembly. It had to be cut/mangled off. After installed i hated the new ones, felt stiff and hard to find gears, i lubbed them up with some 3in1 oil, now there great.
i finally got it off, i ended up taking the whole arm off so i could bring it up, still a very big pita though .
shifts feel a lot more solid and click .. still getting use to the feeling though. but seems alright at the moment ! thanks guys !
I used some pliers and a flat head screw driver to pry it off.
hahaha I agree, mine was a PITA... but I lubed it and lubed it and let it sit with PB blaster, finally I pulled like a **** and it popped off and bounced off the ceiling in the garage and I found it a month later on the floor behind the work bench
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
24
Jun 1, 2017 09:07 PM
Kracka
83
Jan 20, 2017 12:54 PM
sikwititevo9
Sep 16, 2013 07:34 PM
