Helppp my fuel gauge is not working after double pumper install please!!
Installed a home made double pumper baught from good seller.
Looks same as buschur etc. currently only using the primary pump because I haven't hooked up power for the second pump also not tuned for dual pumps etc..
Ever since install the fuel gauge is not working.
I took out the float/ electrical piece that clips in and replaced it carefully with one that was used but working prior. Still not working!!! Really could use some help - everything is hooked up correctly I believe as I have taken it out twice now with no luck... Any info would be great thanks!!
i once accidently moved the little sensor that the float moved. As I rememebr it, a little circuit board, and a piece of metal that rotates along the board to give the float level. The metal piece is what I accidently bent away from the board. Otherwise, make sure you didn't accidently pull some wires loose during install.
If not those two, i'd talk to the seller. if it's a homemade kit, the only person who knows what it is will be the guy who built it.
420a-t
18
Dec 19, 2012 12:54 PM
MR.06MR
Jun 30, 2009 02:32 PM
