Evo 8 with evo 9 turbo help
I have a 03 evo 8 fq300. The turbo is starting to go in it. I have been advised to change my turbo and put in an evo 9 turbo instead of replacing it with an evo 8 one again.
My engine is basically stock, besides an apexi induction kit and hks intercooler piping. So if I was to change my turbo to a 9 one, would I need to upgrade anything else? Like fuel pump or injectors?
Is a remap necessary after that then?
I tried researching but could not find exactly what to do if I was changing the turbo, thanks for your info.
Would you know how the car will run with the 9 turbo after I change it before I do a tune? Like will it be drivable?
It depends on what fuel your going to run. 9?oct on a stock IX Turbo, stock injectors are fine. You'll know once you start tuning, at 9X% duty on stock injectors will still be stronger then your current turbo and safe. You can always upgrade later and sqeeze more out of the tune.
Thanks
Here is a link to the Kit. You don't necessarily have to buy it from them, I just happened to find it on their site first.
http://www.maperformance.com/maperfo...l#.UPCjc6xyHTo
Thanks for link!
Another question, after I fit the turbo can the remap be generic (not on a dyno just plug in computer) or does it have to be a custom remap (on the dyno)?
Cheers
Cheers
adcgn45
20
Jul 24, 2010 10:18 AM
