Bad boost gauge?
Bad boost gauge?
My little brother went and picked up an 06 9 the beginning of this week. Owner claimed it pushing 25psi and the gauge backs up that claim. However according to my feel, and the bov, the car is building boost while in vaccum. In my small amount of experience I didn't think that to be possible. Is the gauge no good? Or can it be adjusted at all? Or am I just an idiot?
Here's a short list of mods
-Bren tuned
-Walbro 255
-Injen intake and upper intercooler piping
-AMS lower intercooler piping
-AMS full exhaust including high flow AMS catalitic convertor
-Hallman manual boost controller
-Bren tuned
-Walbro 255
My BOV (TiAL) releases air in the same way - no boost, either a quick short rev up or easy driving with quick throttle release.
From what I am understanding in your posts, this should be a normal condition. Depending on your BOV, the spring tension should be set in relation to your vacuum at idle. This allows the unit to release air anytime it sees a higher pressure and then quickly goes back to idle vacuum levels (at least).
It is safer on the turbo to have a proper fully functioning BOV that releases more frequently (such as both of our situations), than to have a "stiffer" spring rate that almost forces you to build 10+psi or else it won't open. The latter would result in compressor surge during most daily driving/shifting.
Just because it is operating without boost is fine, it is reacting to the change in pressure in order to
Keep your turbo happy... You should be fine.
Originally Posted by GTijoejoe
Quote:
Originally Posted by rich3389
Does the gauge read "0" when the engine is not running?
ooooww good question
You don't necessarily build boost to hear a BOV noise......
what bov is on it? open filter element?
turbo cars are very audible with aftermarket intakes.
Posted from Evolutionm.net App for Android
It's a stock bov and open filter element, I think it's fine I was just worried about getting an accurate reading and of all the reading I've done and from you guys have been sayin I positive it was just me over thinking. Thanks for all the help fella's
jtanda430
10
Sep 4, 2013 04:05 PM
