Service engine light(bad afr)
Have an evo 8 with buschur racing exhaust and it hasnt been tuned. Afr idle jumps from 14.0- high 17's sometimes I just get --- I have the aem gauges. Theres also white smoke out the exhaust. Car has service engine light because it runs rich. Will just a simple tune up fix my problem?
White smoke could be from a coolant leak (ie headgasket), clogged PCV or a ****ed up catch can install/plumbing, or many other things. If you have no cat (ie test pipe) and the temps around your area are low, catless cars tend to puff white smoke for a bit longer than usual during warm up
Before you purchase your front/primary 02 (which i think is the culprit of your bad AFR), you can read the voltage being supplied to the 02 via a logger, if the readings are all over the place (ie volts) then your primary 02 is bad...
Not expensive, just time consuming. Really lean AFR's can also puff some white smoke.. If your AFR is outta wack, its most likely your 02.. And yes a tune theoretically could fix your AFR (ie tune completely in open loop), but I doubt you want the problems associated with running open loop 24/7...
Spish
Sep 28, 2008 03:52 PM
