Rear wiper stopped working, sprayer still works.
I checked the fuse and its good. I also check the wires by the motor. The are 4 wires, black is grounded, green does nothing, yellow gets 12 vols when the sprayer is turned on, and blue had 12 volts all the time. All the connections are clean with no corrosion. There are also no sounds from the motor. Any ideas?
Im gunna just Throw out some ideas
Fuse
use multimeter to see if your grounding out somewhere
if no multimeter Take a 12v battery and check at the pins of the plug.
Black is a ground and green is a ground Im 80% sure yellow is for intermintant wiper operation and the blue wire is for continuous wiper movement when the fluid is spraying on the window.
If youre going to test it at the plug make sure you run a wire from the green pin to the other green pin so you dont blow anything up.
Best thing method is to use a multimeter.
Hope this helps im just throwing out ideas to get you thinkin.
Fuse
Sorry just read your OP again. Sounds like youve hit all the bases pretty well.
Try the old school started motor trick of tapping it with a screw driver while is on, maybe the brushes got seized up.
If the motor isnt making any noise at all im guessing she may be dead. Do you have any evo buddies that are cool enough to pull there wiper for you to do a test?
One of those wires at the connector for the rear wiper motor is obviously power. I have no idea which one it is, but there's an easy way to find out. Disconnect the connector at the motor, take your test light and ground it. Have an assistant run the rear wiper from the switch. While he's running it, probe the pins in the connector. If your test light lights up, you have power to the motor and your motor is bad. If it doesn't light up while the rear wiper is being operated, the motor is good and you have another problem. If your fuse is good, this is the first thing I would do. And I'm willing to bet the motor is bad based on your posts.
Thanks for the tips guys!
I did that with a multi-meter and posted the results on my opening post. I just need to see a circuit diagram to confirm the readings and let me know if what I'm seeing is correct. If it is then I will know the wiring is good and just get a new motor. I do have an Evo buddy here, I can see if he will let me try swapping his motor.
lancer586
Jan 29, 2011 12:13 PM
Evofletch
Jan 5, 2011 02:20 PM
