cams or turbo?
cams or turbo?
which mod would you guys go for first? evo8 with some basic mods. I dont like how the power feels like it signs off after about 5500. Had a tune, my torque curve signs off early, or is that normal? any way, upgrade turbo or cams? which will give me a better result. i just want a good street/track car
thanks guys
thanks guys
Cams are usually purchased before an aftermarket turbo, it's considered a "basic" mod. And yes, big cams (Kelford, GSC, Cosworth, etc) will help the car pull better up top. Save the bigger turbo for later, you wouldn't be able to fully take advantage of it without a big cam anyway.
I would go for cams/springs and then turbo, also you never stated but do you have an upgraded front mount, intercooler piping? Also if you go bigger turbo you will have to look at injectors,etc. Ulttimetly its up to you in what your hp goals are, but good luck with your decission.
Id decide Hp goals....Personally a turbo swap with a few supporting mods well be better then a CAM swap....by the time you get down to it cams springs retainers n headstuds plus labor n a tune. Your around same ball park price .....now $/Hp well be definition more with a turbo swap. Our stockers are good but you can only get so much Hp before its reaching its limit even with aggressive cams and better fuel. If your goal is 400 or under CAM swap, if goal is more turbo swap.... But if you want more then 400 then headstuds should be on the supporting mods list. Good luck....my recommendation a credit card with good apr interest and a high credit limit....haha
I would do cams first like gsc s2 or kelfords to gain a decent hp gain and will help out on the topend with the mods you have already. Save up your money for the turbo setup you really want , whether its bigger stockframe or turbo kit with ex. manifold / external wastegate. There are so many options.
Definatley cams. Id do it step by step and get the best out of the engine first.. Cams n springs, then turbo upgrade. U nvr knw, u might be happy with the cams since the turbo shud be good for 400hp
Do cams like everyone else is saying lol. The stock 8 cams suck big time. Go with some kelfords or gsc s2. I have kelfords and evo 9 turbo on e85 and its perfect for daily driving.
+1, cams are very essential.
Don't forget supporting mods too. Valve spring upgrade recommended, along with retainers, headstuds and hoping you have all the other basic mods LMFAO.
Keep in mind the GSC S2 Camshafts are usually occupied for turbo setups 60mm+, so it goes both ways on which should be bought 1st....I would honestly just save your money and get everything together to do 1 complete install
