Strange ticking sound under hood
Yesterday morning on my way to class I noticed that when idling my evo 8 was making a strange ticking sound. I pulled over and popped the hood and it seemed like the sound was near the engine. The sound continued for the rest of the day and I noticed it was slightly louder when it was folder outside. However the next day I drove a bit like a madman and the sound stopped occurring and now the sound doesn't seem to be an issue anymore and I can't hear it when the car is idling, even if its cold outside. Should I just forget about the sound that I heard, or could the sound be an indication of something more serious?
I also just recently had the oil, serpentine belt, transmission fluid, and transfer case fluid changed. I don't know if this may have something to do with it.
I have a clunk in the rear end of my car right now. When the weather changes it will probably go away. If it doesn't I will look into it then. I suggest you do the same.
So I'm not all too sure what these lifters are. Are they in anyway detrimental to the car if they aren't functioning properly? I'm kind of strapped for cash right now so I'm not sure what the cause could be. Also this tick is only when idling. Anytime I'm actually in gear and going faster than 5mph I don't hear it. How much does it cost to take care of this problem? Since the sound disappeared am I alright for now?
I just had all the fluids changed less than 200 miles ago. Should I just let it idle for 10-15 minutes then or would this not be a good solution?
The lifter has an inner piston that fits the outer hull to very tight tolerances. Oil pushes the inner piston up which takes up the slack and removes noise. If the inner piston sticks (isn't moving freely) you then have tick. A particle can get in between the piston and the hull, cause the piston to stick, and then come out. If this is the case the problem requires no further attention other than changing the oil at the proper intervals and using a good oil filter.
Thank you, just the answer I was looking for.
