MYstery SOUND watch video n comment PLEaSE!
that is the address link to my youtube.. there is more than 1 video..
the sound seems like its coming from the rear end but i think it might b traveling down the driveshaft.. i just did All my fluids using redline and diaqueen and that didnt change nething.. you can only hear the sound when im ON the throttle. as soon as u let off the gas it stops.. so thats why im thinken its some bearring.. throwout mayb..? well watch my vids n comment please, id really like to get it fixes bc goin 65-80mph on highway is wen its most loud, but u can also hear it wen cruising around 30-40+
Are you talking about the whine? The only thing I can think of that whines like that is the t-case. Mine got REALLY loud right before it died. Sounded like an F1 car.
ya its like a whine but im questioning wether its the tcase or not ..? it sounds like a bearing of some sort. ive heard of the throw out bearing going but dont know if thats what im hearing? so i dont really know.. ill try the bak seat thing, but its the RS so theres No sound dampening newhere to begin with...
Sounds like a good idea. Typically it's the ring and pinion shredding apart. As long as the case doesn't explode for some reason, it should be rebuildable.
Gold Sponsor
Just fair warning. If you do this and the gears break. You must stop immediately and get the car towed. If you try to drive it with a broken ring and pinion then you will ruin the center diff LSD which will be a disaster and may double the repair costs. As soon as you hear and feel that pop or crunch immediately pull over and call a flat-bed. Any attempt to drive it would be like throwing $100 bills out your window.
Good luck
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Jack
