fp2 cams from 97 gsx on evo 9?
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
New to Evos. I was wondering if I could put fp2 cams for 97-99 GSX on my evo since I can get some dirt cheap. My buddy uses evo cams on his galant vr4 so I'm guessing its possible?
Thanks.
Thanks.
As said above, they will not work. The lobes on a Evo cam are 90 degrees out from a DSM cam. Im sure you can fix this with a set of adjustable cam gears that are marked with 90 degree offset dowel pins for evo / dsm. But as others have stated, I also believe there would be issues around the Mivec system.
1fast97gsx
Dec 22, 2014 09:05 AM
1fast97gsx
Nov 28, 2014 10:07 AM
