electrical system completely dead? won't even unlock doors
drove the car 10 hours ago, like every day. Go to move the car off the street this morning, and doors won't unlock, dashboard won't illuminate, nothing.
I also have a battery charger, so clamped to the battery, still absolutely nothing, which leads me to believe it's not the battery but somewhere else in the electrical chain.
sidenote; on Superbowl sunday was driving for 60 minutes or so, and the entire electric system flickered while on the highway, headlights-dash-radio and the car stuttered during it. So I thought maybe a battery terminal cable was loose, but they're both very snug.
any other ideas? Or else I'll have to have it towed which I really don't want to do.
thanks
thanks
It could still be the battery. If it completely failed vs getting weak sometimes even putting a booster pack to it will not be enough, and replacement is the only option. Other than that search the car over for obvious blown fuses (the larger 30amp + fuses). Start there and if that doesnt work we can get into more detail.
so was pushing the car down the street to the parking lot behind my building, and after 10 mins of pushing, finally hit a big bump and the electrical system suddenly came to life, and the car turned over and started?
Like stated earlier, it's not a loose terminal on the battery, those were very tight. The battery is less than a year old, which I know doesn't matter on small batteries, but it started right up. So that bump in the road obviously moved something, but now I'm worried because it's impossible to know what moved causing it to suddenly work.
yeaz, if a bump gave you power than it sounds like a short my friend. Edit- clean your batt terminals and check the distal ends... check to see if your clock restarts when it dies/then comes back to life.. if the clock and everything is all reset like it lost power than I would guess its somewhere around the battery/hard power supply and not some weird problem with something like security (). good luck.
get your car running then grab the negitive cable and shake/pull on and see if it cuts out.
do the same with the positive side. if it still doesnt die or cut out start shaking every wire harness you can get your meat beaters on and give them hell!!!!
yeah good idea... try to get it to cut out when you're running... I'm not entirely sure about this, but I think sometimes with some batter types and depending on how it's terminals are built into the cells, if they get damaged internally than they can cut out like that- borrow a friends batt and hook it up if you cant find a loose/bad connection.
cnj4ever
81
Jul 12, 2020 02:12 PM
DaRw1n
Oct 21, 2016 05:51 PM
