Windows?
If you go oem check this place out http://www.mitsubishipartswarehouse....t=Door%20glass
http://www.acwmotorsportplastics.co....dows-pair.html
Yeah, scratches would be an issue, and it will yellow over time (so better to store in a garage if you do put Lexan on it). The link you have shows that it has UV protection film on the surface, so it should keep it from yellowing for the most part. It should be strong, but it might be safer to go with normal glass. The side glass is safety glass, so it will shatter and crumble in a crash or roll and not end up slicing through a body part.
I would still go oem, on the front like others said they may not be Dot and street legal approved.
V.8MR
Apr 5, 2017 11:53 AM
