nice intercooler
#47
Yes Tiago ....I couldn't use them and I was frustrated trying to get them to fit .....I finally gave up and came to my senses, to just use longer ones with a 45 degree bend ....they are old ones but now the setup fits perfectly .....once I got my old couplings on, I yanked on both charge pipes pretty hard and they are now snug as $#!+ ....I currently run 30 psi and do not want to have to pull over and go through that again, my T-Bolt clamps sit perfectly at a 1/4" away from the edge of the couplings and far enough inwards of the beading on the pipe ends ...now I am a happy camper
#48
Not Evo related, but i owned a VRSF fmic kit on my 2g DSM and it was great.
The shortest route for piping offered in the DSM community and performance was great.
Didnt see any pressure drop up until 28psi.
For the price you cant go wrong.
#51
I know I'm still somewhat of a "Noob" (or "newb", however you prefer) but there's a bit of discussion of the types of intercoolers that give a variety of performances. Its beyond just who makes them, but how its made..
take a look, and let's continue this discussion.
An intercooler's “magic” centers on air density. During compression, charge air is heated and with this heat comes a decrease in air density. Density can be viewed as the amount of molecules in a given volume of air. Intercooling reverses the heating trend and endeavors to recapture some of that density.
The amount of density regained depends on the ambient temperature of the air (in air-to-air units), the efficiency of the compressor (max boost, wheel efficiency etc.) and the cooling capacity of the intercooler.
A properly sized turbo that operates at or near its peak efficiency will not heat the charge as much as a mismatched unit that has to overspeed to generate the desired boost. This extra effort results in a chopping of the air, which nets high outlet temperatures.Because of its charge chilling capabilities, the intercooler also ups the detonation threshold and, as a general rule, a good intercooler will allow you to run three to four more psi without experiencing any detonation.
Tube-Fin Intercoolers
Let’s look at the tube-fin designs. These include the higher end companies of GReddy, HKS, and PWR. The lower end ones , which require a lot of surface area in order to cool, are the CX Racing, Johnny Race car, Godspeed, etc.
Typical tube-and-fin units utilize extruded tubes with fins pressed into place. In order to achieve strength, a thick, extruded tube must be used.
The picture below shows a fin comparison with the popular low-pressure drop, high-speed plain square fin used in CX Racing, (right) and an offset fin design used in GReddy (left) . The offset fin will allow the air to travel slower through the core (more pressure drop) but the air will have more time in the core for heat exchange. Apexi’s Delta Design also uses an off-set design that works extremely well.
The tube-and-fin core is held together and its seal is created at the joints at the end of the plates, which is usually .125 inches thick. The width of the tubes is less than the width of the side plate. Space is lost where the joints for sealing are used. So a 3.5-inch core will have tubes only 2.87 inches wide. Tube and fin has a larger leakage rate compared to bar-and-plate cores. Furthermore, tube-and-fin cores are more susceptible to road damage from rocks and debris than bar-and-plate cores; big trouble in front-mount applications. The oval tubes are extruded from thin-wall material and any sort of extreme pressure can cause these tubes to 'balloon.' But that is extremely rare, and only if the quality is ridiculously poor.
But they are very inexpensive to make, and given the right amount of surface area, can do a great job of cooling. But they have to be pretty tall in order to do it correctly. The smaller ones under 7" in height really only can do about 350whp, then its about done. Even the taller ebay ones have to be big to work properly.... but they can work properly provided it was constructed without leaks.
Bar & Plate Intercoolers.
Ok.. Bar & plates.. Everyone’s favorite. Many companies started doing Bar & plate intercoolers after Spearco and Garrett (and their vendors) rocked the house with their designs. They started improving their designs even more as of 2008-2011, but in the meantime, companies like Precision (who used to use Spearco), Mishimoto, Treadstone, and some private labels.
On the ambient side, where oncoming air streams through the unit, fin design is equally important. Fin density here also impacts cooling performance but there is often the vehicle's cooling system to consider.
This is a louvered fin system from a Garrett. The first versions for years had two rows of these fins in between the plates of the intercooler. Recently, they’ve been changed to where it has 3 rows of these fins sandwiched in.
Side split fin. – Used on some Bar & plate intercoolers.
A Plain Square fin design from Mishimoto, some private label companies, Treadstone and Precision, (IIRC)
According to ****, Spearco pioneered the bar-and-plate core design. True, the bar-and-plate design is a bit heavier than tube and fin, but this is actually advantageous. A bar-and-plate core can take the damage of front-mount life and endure high boost without flinching. Sealing is superior in bar-and-plate units because the bars and brazing sheets run the length of the unit, providing a 100-percent seal between the ambient and charge sides. A key advantage of bar and plate is its extraordinary variety of fin designs on both sides of the cooler. Further, the height of the passages can be changed by using taller bars and fins, which dramatically expands the possibilities for the intercooler designer. A 3.5-inch thick core gets a 3.5-inch row of fins, not the 2.87 inches found in tube-and-fin designs.
Here’s the difference.
Also, a tube-and-fin design has a lot of room between rows where a bar-and-plate unit can get more rows into a given area with more area per passage which means more cfm and a more efficient unit. As far as big boost goes, the ability of a bar-and-plate core to handle high boost is determined by the thickness of the braze sheets, fins, side bars and top plates. For Tube and fin, its much more about surface area that determines HP capability
The thickness (and the type of fins used) dictates how quickly the charge air will move across the unit while the surface area affects how quickly ambient air will flow across the cooler. The curveball here is fin density. The number of fins per inch will dramatically impact the cooling characteristics of the unit.
Mr. **** states that Fin combination is very crucial when designing an effective core with a very low pressure drop, and that although a dense fin design offers superb heat transfer, this design also creates high pressure drop. Pressure drop is the amount of boost lost by the system as it pumps the charge air through the intercooler. The type of fin-plain, offset, louvered or bump-each has its own unique heat transfer characteristics.
So how do you pick? Think about it. when choosing any intercooler, the key is that a balance is met where the effectiveness is attained and a low-pressure drop is achieved.
For example, a plain fin design offers an exceptional low pressure drop but does not provide great heat transfer compared to a louvered fin or an offset fin. The air moves quickly over/through the plain fin (low pressure drop), but is so fast it may not be in the core long enough to maximize heat transfer. Consequently, air moving through a louvered or offset fin takes longer to move through the core (more pressure drop), but it also has more time to transfer heat.
Surface Area vs. Thickness of an intercooler
Ok.. So now you’ve got the right type of intercooler you want.. which is better, to be thick or to have large height? While not trying to snicker thinking I’m on an ENZYTE commercial, I think of this rule of thumb.
The rule of thumb here is actually rather obvious; bigger is better. More surface area means more cooling power. However, a larger surface area is favored over a thicker core. A larger surface area provides more cooling face for the ambient air where a thicker core might be less effective.
As the core gets thicker, the ambient air traveling through the core is heated by transfer and the farther through the core it travels the hotter it gets. By the time the ambient is at the back side of the unit, it's lost a good percentage of its cooling capacity. Beyond that, thick cores cause an ambient pressure drop, which means less air will make its way to the radiator causing overheating issues
**** agrees with this concept. He states that when it comes to area, achieving the maximum height is more beneficial than widening the unit.
The main reason for this is pressure drop is greater when the charge air has to travel through longer passage compared to a shorter passage. It should be noted that pressure drop through a longer-passage core can be compensated for, to a certain extent, via fin design.
With bar and plate being so superior, one has to wonder why even bother with Tube/Fin setups. Its very simple; It's all about cost. The tube-and-fin core is much cheaper to produce and is often used in OE applications, which inherently run lower boost levels.
So remember, gents, Intercoolers do a lot more than look good behind a custom bumper cover. Their atmospheric magic is the result of technical factors such as area, thickness, fin design and fin density. Controlling the flow compromises and cooling advantages of these factors will determine the ultimate driveability of your turbocharged beauty.
#54
No problem. Now that ARC is back, I have information on those as well, but I've noticed that most Evo owners don't really use them as much as the ETS, Precision , or Vibrant.. I don't see a lot of Garrett users on here.. that's interesting.
#55
ETS CORE
E-BAY CORE
CURRENT ETS CORE INVENTORY
Garrett Core cut in half so you can see fin design.
Garrett Core (TOP)
ETS Core (BOTTOM) - You can see our cores are put together with no restrictions in flow path.
ETS Raw Material Shot
ETS Fin Pack - Offset and Staggered. I can go into more detail about the fin pack, but we will save that for now.
Difference in charge row height. ETS has more heat transfer plates due to the smaller charge rows. By doing this we also loosen up the internal fin pack for more flow but more heat transfer area.
Heat Transfer Testing - Fluke Test by Garrett (ETS Core @ RRE)
We also don't use a painted core, most ebay intercoolers use painted cores with an epoxy coating to hide leaks instead of actually pressure checking the intercoolers. Are intercoolers are pressure checked at 40psi+
You will also want to keep an eye out for intercooler cores cut with dull blades. They leave little fragments of metal that can make their way through your cold side piping and into your motor.
*** You can see the little pieces of metal on the blades (this happens from dull cuttters) We reject cores like these. Don't be fooled by a core that looks dense because it has extra material hanging from the fin pack.
Thanks!
Michael
1fast97gsx
Jan 1, 2015 06:32 AM
