I need BIG help...
stereo install? double check their wiring and make sure they didnt do a poor job tapping into a live wire possibly causing your issue. sounds like they might have forgotten to insulate a connector or something came loose . jack points are behind front wheel on pinch rail and in front of rear wheel...manual shows you proper jack points. I've used the rear diff and front cross member on my evo 8
Problem solved, took the starter off, had it checked out and it failed, only negative to the situation is where I live, they don't have any in stock at any parts house, but a local parts store was able to locate one and will be here tomorrow thanks guys for all the help!
EndlessRed
Jul 17, 2013 09:06 AM
