I need BIG help...
I need BIG help...
Guys my car when you turn over the switch the fuel pump comes on but it will not crank, wont even hit a lick, lights are bright stereo plays, battery shows 100% charge, replaced it even still nothing... What gives?
it does neither, you turn the key to the start position and all you can hear is the fuel pump coming on.... doesn't click or anything, which led me to believe it was a fuse or wire type issue rather than a starter issue.
Check the starter/ignition fuse by your left knee behind the dash. It's the fuse you have to change when you put a COP system in.
yeah, I am about to go out to my shop now to check it, where is the starter located on these cars, I've only had it a month lol... checked fuses, they seem to be intact, gonna check the clutch switch next, then the starter wire.
If it helps further diagnose the problem, it was hesitant to crank a few times last week like spun over a few times before it hit, but the next day it fired up fine and has since, it threw a check engine light upon cranking slowly last week. I had a stereo system installed and didnt have any of these issues until after the install.
