evo 8 fog light wiring
i have an evo 8, it has the fog light bulb inner side of the head light, i want them working but i cant find any where to get a wiring kit, can someone help me out on where i can find one???
This is from memory but the first 8's had hid and fog lights. Then succeeding years saw the GSR get regular headlights. So, I take it, some previous owner has installed hid headlights but never connected the fogs.
its 2005 evo 8, has the projected head lights, but your probably right.
do you know where i could buy a oem wiring kit with the button? ill even buy a full aftermarket kit just for the wiring and button
As I understand it, push the fog light button in my car and a signal is sent to the steering column computer. The steering column computer then sends a signal to the under hood computer which then grounds the coil in the relay for the fogs. My guess, but search around I may be wrong, is that trying to get this to work in a car that didn't come equipped with fogs is futile.
So, not having done this or having done any research, I suggest buying the switch for the dash, running a wire out to a relay under the hood, the relay, properly fused for the load, connected to the battery. That would give you operating fog lights but lights that wouldn't shut off automatically - a nice feature.
Alternately, you could search for a part-out with all the needed pieces.
i have an 03 evo VIII, it has HID headlights and has a fog light hid bulb also. All the wiring from the bulb seems factory and i found the fg light switch in the trunk.... can i just connect the fog light harness to the switch and it should work? I read the harness is just unplugged under the dash
marshall15
04-06 Lancer Ralliart How To Requests / Questions / Tips
Aug 21, 2006 09:58 PM
