Hallman pro mbc problems low boost
i have it out and apart right now actually and i found a really tiny little plastic pipe thing about the size of half a grain of rice do you know what that is? it was under the spring and ball against the screw. and what your saying is that i want to tighten the controller all the way down like max boost? because i did that and im pretty sure it is adjusting i see the screw moving with the top and the top moves down with the screw.
yeah it should be moving freely now, Not sure why it wouldn't be working dude, seems to me like your still just not adjusting it down at all... all the way up its like 12 lbs or so.. which is stock wastegate pressure..
so two options:
one its not adjusted down enough still.. it should turn around like 15 + times from cap off untill its tight..
and two, its installed wrong IE backwards, internals upside down or something the spring should go in first then the ball then the nipple line. make sure you have caped everything off and other then that idk bro.. goodluck
so two options:
so two options:
so two options:
Ok I got it. The thing said to start with one turn and it didn't do anything so I have it like 3 more n stil didn't do anything but I turned it like 6 times and it adjusted. I didn't think that it would take so many turns
OneCrzyEvo21
Aug 14, 2014 07:11 PM
whotippedmycow
Nov 25, 2013 02:23 PM
