Reverse Intake manifold aftermarket
Ok does anyone make a reverse intake manifold or a shorter one the stock. reason is i installed a 4g63 in a 911 porsche. The only problem I ran into is i can not plug in the AIC it hits the rear fire wall.
link to build.
https://www.evolutionm.net/forums/ot...wap-again.html
link to build.
A lot of people just cut the 4g63 one and have a flange and hole drilled welded to the other side.. Check out the threads of people putting it in the mighty maxx truck. Good luck
Here is a link and video to the build, you can see how the motor sits.
https://www.evolutionm.net/forums/ot...p-again-7.html
mitsu_lover625
41
Sep 28, 2006 10:31 AM
