Mini battery vs battery relocation?
Old Apr 5, 2013, 10:21 PM
Evobro19's Avatar
Originally Posted by jager89
Haha are they really that small?! I can't say that I have ever looked at one
I guess saying that they are identical in dimensions would be a lie but they are pretty damn close. Take a trip to Autozone n find out lol.
To each his own tho
Old Apr 6, 2013, 03:10 AM
Ben_wiggins's Avatar
I don't understand the problem with the mini batteries and not starting.
I left mine for almost 9 months without starting. Started first time when I cranked it over. Didn't even change the battery.
Old Apr 6, 2013, 07:07 AM
jager89's Avatar
Well my thing is, I don't want to pay the money, only for the mini battery to take a **** on me in the middle of AZ summer. I don't have a charge station, and I read you can't jump them. The miata battery sounds legit though haha. Especially since its warranteed. What mini battery's are y'all running, brand wise?
Old Apr 6, 2013, 07:29 AM
211Ratsbud's Avatar
My pc680 started my Evo all winter in upstate ny, -*f consistently . It died when I left my key on then I jumped it, worked fine. Then I left the key on again jumped it , it's still cranking fine.
I have an rs though no radio power anything
Old Apr 10, 2013, 07:54 PM
jager89's Avatar
Will the miata battery allow the short route uicp to fit?
Old Apr 10, 2013, 08:29 PM
silverevo05's Avatar
It allows my Muse short route which if I've been told is a bushur knock off
Old Apr 10, 2013, 08:43 PM
Go_Lancer_Go's Avatar
can u get ones with good cold crank amps?
Old Apr 11, 2013, 06:44 PM
studioface's Avatar
I was in the same situation the other day and I went in the trunk and skipped using mini battery because you will always have it in the back of your head that one day you will go in the car and it wont start.So I went stock in the back and for the price between both is almost the same and might be cheaper either way depending on where you them from.
I ran #2 Welding cables which are the best of the best,20 feet red and 5 feet black should be more than enough to have your battery fully installed.Also put a breaker instead of a fuse on the line so if it gets tripped you can always reset it and find your way back home.Here is how mines looks,nothing fancy and once the OEM battery is dead I will be using a Interstate Mega-Tron II MT-51 Automotive Battery 500 CCA which is a little lighter and still has great cranking power.Good luck!
Tommyfacekicker (Jun 26, 2019)
lghtngyello03
24
Sep 14, 2016 08:21 AM
Wapoosh
For Sale - Miscellaneous Automotive
May 10, 2016 05:57 PM
91mm02Z28
Mar 10, 2016 07:01 AM
genesisevo
Feb 3, 2016 11:40 AM
Insanity Evo
Dec 17, 2014 08:17 AM
Quick Reply: Mini battery vs battery relocation?
