Best bang for your buck? Im guessing ecu?
Hey i wanna do a nice performance upgrade on my evo but im not sure what to get. Ive come to the conclusion that i want a xflash from vishnu but they dont seem to like to answer emails as i sent them one on friday and another yesterday and still no answer. Anyone know how i can get the best performance for not so much cash. So far i have a rmr 3inch catback exhaust and a turbo-xs hp manual boost controller. If an ECU is the best way to go, which one do u recommend?
-----VENDORS-----
Please do not advertise here. Im looking for responces from the average joe evo owner/modder. Not a sales pitch.
-----VENDORS-----
An ECU flash is the easiest and best bang for the dollar deal you can do.
As far as which one to choose I can only comment on the Works P1 and P2. P1 being a dramatic improvement and P2 being just plain hellacious and my favorite. If you were to get the Works flash you could have it flashed for their cat back system to take advantage of your setup. I would ditch the MBC though.
don't ditch the MBC... it will work fine, best bang for the buck is gonna next be a downpipe, and hi-flow cat.
an ecu flash will enable the tuner to make alot of horsepower, and the best thing is... is the flash is now the "stock" settings, so when your battery is reset you go back to the original settings the tuner put in.
Along the same lines.... I want to incrementally increase the performance of my evo. I live in Calif, where 91 octane gas is the best I can get. I have played around with the idea of buying toluene and adding some to each tank of gas - expensive and a pain in the ***...
Am I better off getting an ecu and running crappy calif 91 octane gas?
Someone told me that by changing the parameters of the ecu I could get the same performance out of 91 and 94 octane gas. This doesn't make sense to me but is it true?
Re: Best bang for your buck? Im guessing ecu?
-----VENDORS-----
-----VENDORS-----
Just so that you can have a safe and constent power.
ECU reflash is a good idea for a performance mod. I would suggest getting a full exhaust with a highflow cat to maximize performance.
IMHO.
Eric
Regards,
shiv
Oh im glad. I heard u guys were real quick with responces so i was a lil confused. i was working yesterday so the whole holliday thing didnt really register. I also thought maybe u guys still checked ur emails at home or sumthin. I hope u get a chance to answer my email soon. Thanks.
IMHO use a MBC and drop your boost to 18...it's the only way to maintain timing and keep the car as lean as possible on our 91...You can run higher boost but the ECU will both add fuel and remove timing to avoid detonation...both of these moves KILL HP.
Originally posted by mayhem
I was referring to ditching the MBC if you have a Works flash, especially the P2.
