Need a good PSI reading gauge!!
i'm looking for a good boost gauge that reads in psi not kPa or bar or whatever. (don't want to have to take the time to convert it) then after i get some help on gauges from you guys i need you're suggestion on which gauge pod to use. there is the one at buschur racing http://www.buschurracing.com/EVO8_BoostGauge_Large.jpg that i like but it's only in 52mm (2 1/16") and i can't find any good looking gauges that are that small. on the other hand i like the RMR Carbon Fiber Gauge Pod http://lancershop.com/gauge_pods.htm (the one that sticks to your factory steering wheel cover.) but that only fits 60mm (2 5/8") which is the size that i need for the gauges that i want but they don't read in psi. if you guys have ANY suggestions i'd appreciate it. also do you know if the RMR carbon pod requries any cutting into the factory steering cover?
Thanks guys!!!
Ben
Thanks guys!!!
Ben
