can I crank my boost up 1psi without a tune?
Old Apr 24, 2013, 08:33 AM
  #76
Danner's Avatar
Oh, that explains it then. an Evo IX has mivec and a bigger turbo. Id say you are about where you need to be.
  #77
CurseDSM's Avatar
Originally Posted by foxracing515151
I have tubular exhaust mani, 3" 02 housing, full 3" catless turbo back, intake, 3.5" front mount, licp, mbc,big radiator and a walbro 255 in the tank. I believe ivey has a dyno jet not a mustang. So on a mustang it would be what 10-15% lower than the 310 on the dynojet right? I coulda swore id be at least 340 wheel on a dynojet. Oh and I have an viii.
There is a lot of factors that could be had though. Mods do seem right, but at the same time was there a boost leak? What was your afr tuned to? Maybe you didn't have the injectors to get you there and that's tuned with the stock injectors. Although I doubt that being you should make around 400 with stock injectors or at least close to it. It sounds like you have an issue somewhere, or take it to another tuner.
Old Apr 24, 2013, 09:56 AM
  #78
foxracing515151's Avatar
Thats what im thinkin everyone says stock injects are fine up to about 400hp. My buddys got the same car as me, same mods but with gsc s1 cams and meth/water making 390 to the wheels. tuned at the same place on stock injectors. He said his duty cycle at the top end is 95% so im thinkin they werent the problem. I also had them do a boost leak test before the tune and all was good. Only thing I can think of is, it was a busy *** week right before a holiday weekend, and they flew through my tune just to get me out the door. Maybe flashed my ecu with a tune from a previous car with similar upgrades and tweeked it a little from there and went on to the next car. I left the shop believeing I was at 25lbs of boost if I knew I wasnt I woulda asked further into detail but they dont remember now what the situation was 6 months ago.
Old Apr 24, 2013, 10:42 AM
  #79
CurseDSM's Avatar
I don't think it would be a previous cars tune being the car wouldn't act right. With the addition of cams yeah your gonna see more power, but this isn't your case. I would call the shop and have them look over your tune again. I agree the #s are low, but maybe your car just doesn't make that kinda power. In that said maybe they forgot to flash the last flash to give you the 25 psi of boost you think you got. I would have them look at what they gave you to whats actually in your rom to see if it matches. 95% injector cycle is a bit high and to me I wouldn't want to run that all the time. I would definitely bump the injector size at least one size if your not going to a larger turbo. Another thing I would suggest is let them know they told you were tuned to 25 lbs and the car does not see it. And give some bull**** excuse that you haven't been driving the car and never really noticed it till now. All in all either go back to the shop and ask them about it or just give tscomptuned a call and he will give you what you need. I mean I don't mean to plug Tom or nothing but he is the only tuner I will allow to touch my car.
Old Apr 24, 2013, 08:04 PM
  #80
Wheres he located? Got a link to his site?
Old Apr 24, 2013, 08:10 PM
  #81
Cudi's Avatar
I turned my boost up 1psi on my mustang an my car ran a half second faster! Depends which platform your on: Playstation or Xbox. Seriously, don't touch the boost controller without experience unless you like fixing ****.
Old Apr 24, 2013, 08:13 PM
  #82
CurseDSM's Avatar
Click on the link above my hp and tq #'s tell him I sent ya. He does remote tunes and he lives in PA.
Old Apr 25, 2013, 07:15 AM
  #83
Says google subscriber not available. I left a message. Does he have a shop with a dyno? Id much rather go there im semi close in jersey.
Old Apr 25, 2013, 07:41 AM
  #84
CurseDSM's Avatar
He will remote tune your car from home. He isn't really a big shop. Trust me he is one of the best tuners if not the best tuner on here. I would send him a message on here, or email him off that site. Trust me when I say it is well worth it. Look him up on here for his work.
Old Apr 25, 2013, 11:25 AM
  #85
Ight cool thanks, thanks everyone for your input.
Old Apr 25, 2013, 11:29 AM
  #86
CurseDSM's Avatar
He makes it pretty easy for you and you don't even have to go outside of the state or anything. Plus he works with you till its perfect for what you want.
Old Apr 25, 2013, 12:22 PM
  #87
matrho2792's Avatar
If you can't get a hold of him I'm pretty sure Aaron at English Racing can do remote tunes as well. Just look him up if you have any questions
Old Apr 25, 2013, 12:28 PM
  #88
CurseDSM's Avatar
Yep another good choice. Although I am a little bias being Toms a buddy of mine hahaha.
Old Apr 25, 2013, 01:08 PM
  #89
joseph143's Avatar
i'm subbing in so i can send links of this thread to my friends so we can laugh at how stupid the people in this thread are...
Kevoix
Apr 10, 2016 10:12 AM
mrdecrypter
14
Apr 8, 2009 02:42 PM
03ah8
Mar 17, 2009 10:04 PM
ant_turbo
Oct 30, 2007 04:54 PM
Quick Reply: can I crank my boost up 1psi without a tune?
