removing stuck loctite plug
So... I have a very very stuck hex socketed threaded plug with red Loctite on it in my full blown double pumper outlet. I want to change it out and install a NPT to -AN hose adapter in there. Any thoughts on how to remove? any more wrenching and Im going to bend the aluminum housing. Ideas?
I've used carb cleaner before. If some threads are exposed spray it on and let soak, like overnight. I then put a little torque on it (righty tighty) to break it loose and was able to extract the fastener. Granted, it was in steel and I got lucky, but aluminum I don't know. You may just end up pulling the threads out with the fastener. Good luck.
Svendiesel
14
Jan 19, 2012 03:18 PM
