Moving to VA.
Old May 10, 2013, 05:41 PM
misterevo8's Avatar
Moving to VA.
To all the VA guys, i will be moving from cali to VA soon. will i have to smog my car once i get there in order to register it or will it be okay to just register it because i will be in souther VA area? thanks guys i appreciate the help.
Old May 10, 2013, 05:49 PM
TSiAWD666's Avatar
You're going to have to pass the obd-2 checks for emissions.
Old May 10, 2013, 05:52 PM
fugiwara's Avatar
OBDII check is not the same as SMOG. It basically is plug into the OBDII port check for CEL, it's much easier than SMOG. Do they put a sniffer in the exhaust pipe?
Old May 10, 2013, 06:22 PM
misterevo8's Avatar
will that include the undercar visual and under hood visual or just obd2. i will be fine with just the obd2 check.
Old May 10, 2013, 06:25 PM
TSiAWD666's Avatar
Just the obd-2. You still have to pass the visual inspections for things like dash lights, brake pads, tire wear for the safety inspection, but for emissions it's just the obd-2 checks.
No, they don't put a sniffer in the exhaust. Well, not for his year car. They used to for much older cars (pre-96) but I don't know if that's even still done.
Old May 10, 2013, 06:28 PM
misterevo8's Avatar
and, i thought anything related to emissions was just for northern parts of VA or is it the same for virginia bea, norfolk, chesapeak area?
Old May 10, 2013, 07:02 PM
chrisw's Avatar
dude... assume the worst. you are moving to the fascist state of Virgina.
Old May 10, 2013, 07:20 PM
NJ_evoIXgsr's Avatar
I hope you are moving there for military purposes because they are D-BAGS! You should only have to do obd2 check, no sniffer, easy to pass as long as you don't have a CEL. I don't remember if visual check was absolute necessary.
Old May 10, 2013, 08:21 PM
misterevo8's Avatar
yeah i have no CEL i was only concerned about the perrin intake, DP and HFC.
Old May 10, 2013, 08:25 PM
CDHoff's Avatar
I believe it's only here in northern va that there is emissions testing. Counties south of here only have the visual inspection. I'm not sure about the va beach area though. There is no sniffer they just plug into the car and check for cells and they make sure your emissions equipment is working. The visual inspection consists of a brake check, tire check, lights, signals, and catalytic converter. Inspection is every year and emissions is every two if you pay a little extra(well worth it). VA is a great state but its tough for car guys. There are cops EVERYWHERE!!! Hope this helps and welcome to VA.
Old May 10, 2013, 08:28 PM
misterevo8's Avatar
so would i pass the visual with a UR HFC and the DP?
Old May 10, 2013, 08:34 PM
Just stating. There are a lot of shady guys in VA. If you meet enough people, you will find those that have hook ups to pass inspection without an inspection. Lived in VA beach from 2002-2007 for Navy.
Old May 10, 2013, 08:37 PM
TSiAWD666's Avatar
You won't have any issues with parts. We aren't as bad as California. Well, except for exhausts, any coffee can muffler will get you a ticket.
misterevo8's Avatar
thanks for the info guys, i appreciate it. any more info would be great!
Old May 10, 2013, 08:45 PM
CDHoff's Avatar
I've had my buschur exhaust with HFC and magnaflow muffler for years and I've never had any problems with cops.
Quick Reply: Moving to VA.
