Evo 9 Chain like noise from rear
So i notice when i go over bumps, or drive on a uneven road, i hear this chain like noise from the right rear, it sounds like if i was dragging a chain. Any ideas what it would be? Im guessing the noise started today because yesterday i didnt hear any noise. All help greatly appreciated. Edit- i think its from the rear i had a friend in the passenger seat and was told it sounds like its coming from the rear
If it makes any difference. I have a 06 gsr, mods that I know of, are walbaro 225 fuel pump, aftermarket injectors not sure which ones, tunabi cat back, no catalytic converter, after market intake. It recently got slotted and drilled rotors I stalled and new break pads. It's tuned but idk to what( don't know about tunes) I have the dyno paper work tho. Can anything installed cause something that sounds like chains being dragged ?
does that noise occur only when you hit the bump, then once the road smooths out it goes away? Or does the noise continue? I ask this because if you hit a bump and it clunks or clanks, it could be multiple things.
For example:
-exhaust hitting something
-rear sway bar link, or sway bar bushings worn out
-rear control arm bushing worn out
-rear strut mount
For example:
-rear strut mount
For example:
-rear strut mount
For example:
-rear strut mount
Only only bumps or uneven roads. It goes away after. No clunks or clanks either. I think I found out what it is. I think it is the splash, dust shield behind the right rotor. I didn't get a chance to completely check it out because it was late but, if I hit the Right rear wheel with my hand, I can hear a rattling noise, and when I hold the splash shield and hit it the noise stops, so I'm assuming it is that. Maybe the shield is loose or something?
FoxFister
Sep 4, 2014 01:48 PM
