Water in a tale pipe and half coolant missing from reasivor after Hgasket change
I recently change the gasket and decided to go with stock evo gasket and arp bolt all the bolt were lubed and tourqued properly day after i got the car i was driving and i started smelling something as i pulled into the drive way i opened the hood got some smoke for about 30 sec which looked like it was coming of the flex pipe the next day i drove my car to work came back sat in my house for about 4 hr and went outside turned the car on and i let it idle after about 5 min i notced coolant was missing from resivor i walked to the back and noticed some condensation inside the tail pipe... help guys!!!! is it what im thinking it is??... what can i do in that case ??
was it condensation or coolant in the tailpipe? condensation is normal. check your oil and your coolant for milkshake. it's possible that you just didn't top off the coolant after driving it. does it drive differently or overheat? also the smell of coolant in the exhaust is pretty noticeable, and white smoke would be pouring out, even after warming up.
well its not smoking and the thermostat was changed so it was properly bleed before i even go into it but it was yesterday when it was really hot and i ran it and saw some white smoke coming from under the hood i look under the car and it looked the the flex pipe was smoking but there wasn't any coolant on the ground since then i have been smelling allot of burnt fuel and i noticed the coolant missing so far there wasn't any abnormal temperature spikes
If you installed the gasket and the deck was wet it wouldnt seal even if you use apr studs... Especially if the moly from the studs gets on it... However shooting in the dark is pointless without results... So test it... Rule that out... Monitor your coolant levels for a week or so... And then assume you did a ****ty job of burping the system and it sucked the needed fuild from the overflow...
this...............
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Qshiplvr
Feb 9, 2015 11:18 PM
evolvedevo91
Dec 30, 2014 02:56 PM
<mojo>
Lancer Troubleshooting
12
Nov 12, 2012 02:07 PM
