Want to see what other people are running with the same set up
Hope everyone is having a good week so far. I have a quick question, what are other people hitting for AWHP with a similar set up to mine.
AMS Turbo Back Exhaust
AMS Lower Intercooler Piping
AMS FMIC
AMS Intake
255 Fuel pump
Tune
AMS FMIC
AMS Intake
255 Fuel pump
Tune
I have is have similar mods, I'm tuned at 26psi tapering to 22-23
4" vrsf intercooler
Injen uicp
AMs lower ic
Walbro 255
Home made c.o.p
Injen intake 4" filter
Downpipe, test pipe and hks hi power exhaust
Tuned by me after I installed the new IC I had to retune cause the boost went down after I went from stock lower icp and stock IC
On vd dyno I made 377hp 342 torque , @3200 pounds 200 pound driver. Not sure if that's the weight I don't have acd or the pump, I have a small battery trunk mounted, solid front and rear mounts, evo ultimate ratio trans, twin disc exedy, Mbc, removed rear electric fan and light weight stur tower brace (tein) koyorad radiator, I gained some torque after I installed the intercooler and retuned the timing
93 octane tune, no knock everything runs perfect, she's a little Bucky thou
4" vrsf intercooler
Injen uicp
AMs lower ic
Walbro 255
Home made c.o.p
27 Psi boost
95 Pump fuel+ NF Ultra octane booster( Our pump fuel is crap here)
Aquamist HFS-3 Water/meth
251 Wheel kw (336 WHP when converted)
520 Wheel NM torque (383 Ft/lb when converted)
AJCaron12
Nov 25, 2012 10:58 AM
