Cams without building valvetrain?
im running comp 280/280s with a 35r kit. i still have stock valvesprings and retainers. my car only has 10k miles on it, so spring pressures probably like new. how crucial is it that i build the valvetrain ? is this something i can hold off on for a little. lookin for some opinionsssss
oh yeah 05 evo 8 btw
For the extra ~ $200 for some aftermarket valve springs it's worth the upgrade, valve float can cause some expensive mistakes. Pick up some BC or Manley springs and call it a day, then sell your Evo beehives to somebody with a DSM on a budget who's still running stock or super mild cams
As a general rule of thumb, anything above 272s, upgraded valve springs and retainers are critical. I havent built too many imports but have plenty of experience on domestoc V8s; however, a larger camshaft improves performance by opening the valves at a different point throught the RPM band and holds them open longer to allow for added air flow. With aftermarket camshafts your sacrifice comes from the lack of low-end torque and moves the powerband to, typically, to a higher range. Because the lobes on the camshaft are longer and contain a higher duration and different lobe seperation angles the factory valves can be extended beyond their tolerence and thus the comment was made earlier about "valve float". When surpassing a cam that overextends the factory design function your limiting the life of your valvetrain and comes down to a hit or miss everytime you row through the gears. Factory camshafts and valves are more than capable of reaching the 8k mark but because of the increased strain on your valvetrain youve limited yourself to lower RPMs...defeating the purpose of moving your powerband, you CANNOT take advantage of your modification until you modify the valves. Im confused as to why you spent the cash on the cams but didnt upgrade your valvetrain, especially when it was already torn apart. I would drive her easy until you upgrade as floating a valve would be bad news, head/piston damage....serious mods require the application of supporting hardware, you wouldnt throw on a 60 trim using tge stock intercooler and piping (youd be blowing hot air and the potential CFMs would be hindered by the restrictive piping not the mention the pressure wouldnt be tolerated by factory worm clamps)....hope this helps
What valvetrain are you referring to? If you upgrade your springs and retainers along with some cams that breathe up at 8000 + rpm then you may want to rev real high. If you mean stock to mild cams then yes I agree , theres no point in revving it higher if its not producing more power.
