Mivec oil line to head
I looked at the service manual and couldn't find it anywhere. The line is listed in the manual as the oil pipe http://www.evoscan.com/manuals/Evo9/GR00002300-11B.pdf page 11B-35. Number 29. The banjo bolt is 28 in this drawing, and the washers are the N on 28.
Its easy man just get a caliper and measure the outside diameter of the bolt (at the threads) and buy the crush washer 1 mm above the actual size .So if the bolt is 9mm at the threads you will need a 10mm (inside diameter)crush washer.I used this method all the time,good luck.
Ok, so after some digging, i found this thread:
https://www.evolutionm.net/forums/ev...-here-263.html Post #3931
So i went to mitsubishiparts.net and ordered part number MF660066 quantity 2
