erratic idling
![Unhappy](https://www.evolutionm.net/forums/images/icons/icon9.gif)
got 2003 evo. engine cuts out when I stop at the light. engine behave normally when cool then idles erratically and die out after being run for a while. notice that the engine emit black smoke and misses when it idles erratically and also the idle get better when I close the blow out valve with my hand. help thanks
^ This or, maybe a f%^&ed up BOV. Sounds like you are VTA, make sure you are tuned for it. if not, put it back on recirc and see if the problem persists. if it does, then try a new BOV, if that dont work then.... take it to a reputable evo shop.
thank you for all the reply. check my BOV and found that it is cyling even. at idle. adjusted the bov and it seem to work fine. I will try to put it back to recirc asap to avoid more problem . thank you again.
JCEVOVII
Oct 23, 2013 05:04 PM
josephcastelar
Apr 22, 2013 11:37 AM
Chamama
16
Dec 17, 2009 10:24 PM
