bad timing belt tensioner?
looking at the timing belt tensioner today, my manual says you should be able to stick the 'granade' pin throught the hole into the rod of the tensioner when proper tension is applied... the problem is that my 'rod' part of the tensioner has spun about 90 degrees to the left, i can see it with a mirrior. my question is that rod supposed to spin inside the tensioner? thanks
