Loud "clunk" sound
Old Aug 26, 2013 | 07:53 PM
alvar350z's Avatar
Unhappy Loud "clunk" sound
I have a 2003 evo 8 and as the title states, there is a large clunk sound coming from center to passenger side wheel when I put it on 1st and drive off. It also sounds every time I hard brake. It started sounding when the car was jacked up real high from the passengers side and brought down. I checked above and below but nothing seems worn out. Am I overlooking something? Anyone have an idea of what it could be?
Your help would greatly be appreciated!
Old Aug 26, 2013 | 08:01 PM
Randal's Avatar
Guest
You could probably look under and make sure all the bolts are tight and not loose. I have a 2003 Also and you hear a lot of weird clunks and noises coming from the front end. You should be fine
Old Aug 26, 2013 | 09:37 PM
impact blue's Avatar
that's from another thread
Old Aug 27, 2013 | 01:47 PM
DSMolition's Avatar
Check to see if you have a coil spring that is broken or not in the right position. I know when springs are not in the right spot in the perch they will make some noise
Check your sway bars and endlinks.Check your drive shaft for play. Get under there, take both hands and try to wiggle it back and forth and note the play.
Lastly, I would check out the rear diff bushings. Make sure the diff is not moving when you are letting the clutch out/ suspension is flexing.
I would start there and start eliminating the most i can.
Old Aug 29, 2013 | 10:21 AM
alvar350z's Avatar
Thanks for the advice guys, will definitely use the 3 day weekend to check it out. any more ideas are welcome
weneversleep
Mar 2, 2014 05:08 PM
SpeedI2acerX
Jan 9, 2014 07:25 AM
ShanesEVO
Oct 20, 2013 11:03 AM
vivac2
Mar 12, 2013 10:52 AM
ThEHiTMaN
Dec 12, 2006 11:50 AM
