Remove Strut brace on engine bay?
Old Aug 27, 2013 | 06:03 PM
Randal's Avatar
Guest
Have any of you guys Removed the Strut Brace on the engine bay? I am thinking of removing it to save some weight as long as its structurally sound. I don't want to compromise something breaking or bending, don't know is mitsubishi had it there for a purpose as for the track or not or cause it needs it to reinforce the chasis or so. . I don't ever do track just the 1/4 mile.
Old Aug 27, 2013 | 06:04 PM
snowmastergt's Avatar
Personally, I would keep it. Or spend the money on a lighter aftermarket one.
Old Aug 27, 2013 | 06:12 PM
hiboost2.0's Avatar
Of course it' there for a purpose, to stiffen the front chassis up. You can take it off if you want nothing negative will really happen, especially if daily driven or in the 1/4 mile. You may notice a small difference going into hard corners.
Old Aug 27, 2013 | 06:17 PM
FQ-300's Avatar
Personally, I would leave it on. The bar only weighs 7.44 pounds with the two center mounting bolts. That's not going to shave off anything noticeable in the 1/4 mile. Mitsubishi put it there for a reason. Most people who remove it, switch to something more "blingy", not necessarily for weight reduction, even though aftermarket bars are a couple of pounds lighter (titanium, even more so.) You're call.
Old Aug 28, 2013 | 03:45 PM
st0k3d's Avatar
I have seen people running without it. You will detract from your handling without it for sure.
Old Aug 28, 2013 | 03:54 PM
Evo_Precision's Avatar
This^.
Will it harm anything? Probably not. Will you gain any time by removing it? Probably not (your body weight probably fluctuates more in a day than the strut bar weighs) and it would detract from cornering slightly.
Old Aug 28, 2013 | 06:47 PM
njboy's Avatar
Leave it on there. That's the best looking OEM strut brace I have ever seen and I'm sure it doesn't weigh much. Move your battery to the trunk or go mini. Money better spent.
Old Aug 29, 2013 | 06:53 AM
SmurfZilla's Avatar
If you take some on and off ramps on the highway with it on and off you will notice the difference. Unless you are drag racing for money or car titles its a waste of time. Why not just take your entire interior out except for the drivers seat. That would be more beneficial and won't hurt the car's handling.
If your daily drive it leave it alone. Its not a civic where getting power out of it with out boost is hard.
Old Aug 29, 2013 | 07:54 PM
Rawger's Avatar
I'm sorry dude but don't do it, that's just stupid. Like someone said just invist on a lightweight one. You take that off the headling on corners won't be that good as it is and hav a good chance on spin out on the track if you track. Everything is here for a purpose on our cars. It's not a civic were it doesnt need it.
Old Aug 29, 2013 | 08:06 PM
EvoJoeIX's Avatar
I havent had mine on for years. It just gets in the way working on the car and i notice absolutely no difference in handling
Just because the car comes with it, doesnt mean it NEEDS it
Waffled
Oct 27, 2014 07:12 AM
bigben
May 17, 2012 04:39 PM
SmokingTires
Jan 30, 2012 09:35 PM
Dropspeed
Midwest Region
Jul 10, 2007 08:49 AM
Shaker Motorsports
Mar 19, 2005 09:59 AM
